Well done Apple you have now completely impressed me!
After bathing my son I was clearing up his bath toys when my iPhone slipped out my top pocket into the water. Was fully submerged for 2-3 seconds
before I rescued it. I heard an electrical buzz that went through the water!! Took it out and shook it - lots of water came out. Left it to dry out
about 8 hours and now it works perfectly!
I'm posting this topic from my IPhone!
Happy days
Wife dropped her Nokia XperssMusic down the toilet. I retrieved it a couple of mins later - it didn't work, stripped it down into about 12
pieces, dried each bit, re-assembled it - it worked......
.....for about 3 months, then it suddenly died permanently
So - don't count your chickens!
That's a result, let's hope it stays that way. Airing cupboard and bags of rice are good for drying wet phones.
Sounds like a lucky escape.
One thing to bare in mind, I am told there are 'water detectors' inside the phone, so if you intend to sell it on at some point, this is a
visible sign its been wet so it could harm your resale value.
Swimbo's iPhone failed the left in pocket and put in washing machine test, guess that was a little more rigorous
One thing to bare in mind, I am told there are 'water detectors' inside the phone, so if you intend to sell it on at some point, this is a visible sign its been wet so it could harm your resale value.
I would put it in some rice to pull any moisture from it electrical circuits usually fail when the moisture has corroded the circuit no when there just wet could be fine but it could be a fiew days before you notice a fault
Anyone seen them bags on gadget show which dry your phone out .....
http://www.save-a-phone.co.uk/
I think I want one of them... They worked well.
Omg I'm bored...
did you retrieve the phone by Apple bobbing? *dun dun ttttsssss*
the last phoen I dropped in water, worked fine straight afterwards. then a couple fo weeks later developed a minor fault, and then 3 months later packed up completely. It will have done damage - the question is when it shows itself!
