An el cheapo Kinzo compressor from a company that has long ceased trading...Blown head gasket.... HELP!
Make one! All searches appear to show that no spares are available, so that limits your options unfortunately.....
Just found a site info@kinzo.com
Try an email with model number and what you need, you never know!!!!
[Edited on 13/3/13 by AndyW]
As said, make one. Or remove the old one and see if you can seal it without a joint (gasket).
Thanks for the responses guys!
...Next question..Where to get suitable gasket material without having to pay a kings ransom?
if you think its worth doing rather than the cost of a new compressor, then High Temperature Manifold Gasket Material |
eBay could maybe do it? Or the sheets of gasket card/paper/stuff off ebay found loads at under a tenner
[Edited on 15/3/13 by AndyW]
What sort of size gasket are we talking here ?
I used an aluminium foil carton and cut the shape out for a moped head gasket and it ran for years on it. I think a compressor would put material under less stress.
...Thanks for that nugget fella.
