My wife wants to set up a Website for her business (which means she wants me to).so we have a name we want to register so advice please on
1. Who to use to register name
2. Where to get it hosted
3. Whats a good wysiwyg tool to use
Cheers pete
sent u2u
Hi Pete
Hope this helps:
1. Who to use to register name - Lots of hosting companies will give you a free domain registration when you sign up for hosting with them. Perhaps
give that a go first, could save you some money vs doing through two separate companies
2. Where to get it hosted - I've used UK2 and webhostinguk.net before and both were OK. Web Hosting UK were really good with their customer
support when I needed some help
3. Whats a good wysiwyg tool to use - Wordpress is a good starter for 10 to look at. If you go for a host that supports cPannel then it'll have
things like Wordpress, Drupal and Joomla available as a one click install, which saves loads of time when setting them up. If you're looking for
something that's more drag and drop then have a look at Moonfruit
Hope that helps
Pete
I build websites for pocket money and my top tips are...
Find a decent host that gives you a virtual server with full C-panel (ideally with something like softalicious to enable quick installation of
applications)
(I use Vidahost for all my websites...knocking on 15 so far and their up time and customer service is pretty damn good)
Install Joomla 2.5 or 3.0 using softalicious
If you search about there are plenty of templates you can use to customise the look of it (you can of course build your own template but it is much
more involved) I use the ones here quite a bit...the prices are reasonable... http://www.joomspirit.com/ They can be customised.... This is one of
his templates that I used.. www.meganhine.com
Once the template is up and running simply build your content/menus.... There are literally thousands of plugins you can get for joomla including
shopping cards, image galleries etc.. There is nothing you can't do... OK so joomla CMS takes a bit of getting used to in the back end...it is
not imediately obvious where things are but once you get your head around it, its a damn good bit of software!
I personally would avoid the generic "build a website" type service where you pay them to host and use their editor...
If it is on your own "personal" server the data is yours, all you pay for is the hosting... you have full control....
http://www.serversfree.com/ any good to you?
LCN are pretty good for registering and hosting. http://www.lcn.com/
A lot the better ISPs such as Plusnet do hosting and are pretty good.
Tip if you can't get the exact domain name you want try using a hyphen in the name for example washer-store.co.uk
Originally posted by Pete - Kit Car Zone
1. Who to use to register name - Lots of hosting companies will give you a free domain registration when you sign up for hosting with them. Perhaps give that a go first, could save you some money vs doing through two separate companies
Thanks Guys some stuff to look at there, Ive now got the slightly harder job of getting the wife to say what she actually wants
cheers Pete
