Hello everyone - We presently have a gas cooker and we hate it. We bought a new one (from Argos) and that was even worse. I don't know if I want
to risk it again so wondered if we had a new 30A supply put in for the cooker what the cost would be?
We only have a standard socket 13A behind the (ex) gas cooker and I don't believe a spur was ever installed (Kitchen is an 1980s extension to the
property)
We do have a fairly new fuse board and it's protected with RCD's. There are a few spare slots as well as one or two redundant ones (water
heater and now a combi boiler)
It would be a run of about six or seven meters in total from the board to the kitchen.
Any electricians any idea of what sort of cost this might be?
Thank you!
Michael
You can run a electric oven off a 13 amp supply, its the hob that takes all the power.
Gas hob, electric oven?
Sorry BVT, should have said that!
It's a standalone unit now - hob and oven in one with a glass top. There's no space in the kitchen to add an built-in unit so a standalone
is our only option I think?
In an ideal world I'd actually like a gas hob and an electric oven - dual fuel?
surprisingly common
Thanks MC - I know....depressing amount of money!
We had a Cannon and that had no temp control. Hadn't ever been cleaned properly and was "grubby" even after a deep clean. Used to take
ages to light and oven didn't seem to cook well at all.
Ditched this for a new Argos supplied Bush. Absolutely terrible appliance. Light in weight (opening the oven door pulled the whole thing towards you),
gas very often went out mid cooking, would never light either and finally even Gas Mark 9 (the highest setting) wasn't good enough to cook with.
Oven chips took well over an hour and still weren't browned.
We only went with Argos because 1 - we thought it would be quick (took 2.5 months) and 2 - It was "cheap" (£350) but we could use some
Nectar points.
Awful piece of rubbish got picked up today and now we have nothing. In my old house I installed a new built in electric hob and halogen hob myself.
The both of them came to about £360 and worked brilliantly. I stupidly thought that I could get something similar again for gas/dual fuel but no....A
long way off!!
So we're presently without a cooker (Microwave though) and I'd love to have decent cooking back so I think it's electric oven and gas
(booo) hob for us?
^^ we got this one:
http://www.johnlewis.com/belling-fsg60dop-gas-cooker-stainless-steel/p231631750
to be honest its not fantastic but it works, I probably turn it almost 1/2 a gas mark higher than normal to get the same result as the last one, but
I'm getting used to that slowly - and gas9 with turn oven chips into charcoal in 5 min flat :lol:
there are probably better ones out there, but she like the look of that one and it was in stock....
my mum got a big fancy 900mm wide rangemaster thing (all electric) and even that has a few niggles and is far from perfect
I guess all you can do is read as many reviews as you can and if possible try them before you buy
john lewis matched the price of anyone else and they delivered, installed and tested it for £75 on a date agreed the day we ordered it (the installers
brought it with them and had it fitted in 30min)
the safety certificate turned up in the post the next week - I was very impressed with the service from them
[Edited on 15/1/2014 by mcerd1]
No better than MC's help.......but just a few more for a bit of choice
Duel Fuel linky dink
Good luck ....
Fozzie
I picked up a very nice freestanding oven on eBay a few years ago for about 80 quid. If you could find a nice secondhand one it would offset the cost of the wiring.
I think regs say you can't run an oven off a 13 A plug but have to have a fixed outlet off a DP switch.
I'm waiting to put in an oven rated at 3KW which is bloody close to 13A so - switch on a 2.5 KW kettle on the same ring cct and the breaker
would go pop.
Reason for my delay is I have to lift carpets to run the cooker feed.
I'm waiting to put in an oven rated at 3KW which is bloody close to 13A so - switch on a 2.5 KW kettle on the same ring cct and the breaker would go pop.
Quite often a 13amp socket is spurred off the cooker outlet box, controlled from the cooker switch.
Thanks everyone, good to hear that the ideal appliance exists.
£200 doesn't sound too bad to me but I suppose adding that to 400 odd for the cooker and then Gas Safe install of the cooker it's all really
adding up!
Anyone an electrician and could guesstimate/ confirm a rough cost of 200 to have a feed added?
I think the feed would be the best way to go, at least that way if we can't get on with a gas hob we could have electric everything!
Michael
