i need to drill a load of 42mm holes in 2mm aluminum,
Normally i'd used a stepped cone cutter but the largest i have goes up to 40mm
I don't like holesaws much as i find they tend to move around a lot.
Also i can't use a pillar drill so can only use a corded drill.
Any ideas on how to do this easily?
cone drill, and then a file? or invest in the next size drill,. or ask a friend?
You could use a Q Max type sheet metal cutter - loads on ebay but not a cost effective one hole solution....whereas that half round file you know you have lurking behind the tin of elbow grease...
i have about 100 holes to do so that q max cutter is an idea if i can find the correct size
Is something like a tank cutter any good? No idea how much they are though!
You need one of those cutters where you have a former that pushes into a tube, like a void bush removal tool with a cutting face.
Like this
eBay Item
Like this
eBay Item![]()
That is a Qmax cutter
Yup. That's a qmax. Grease the thread and piece of piss. I have quite a few now. Lovely things.
Plasma cutter with a compass attachment
