bit out of my depth with these fangled machines
i have a new Beko,just one fill hose so i connected it to the blue tap under the sink,seems blue is hot so it is hot filling,is this going to cause a
problem ?.
i put it on and went out last night,came back about 1 hour after it had finished and the washing was still steaming,obviously as it hot fills,as above
is this a prob or just saving on the electric bill ?.
If it's a single fill hose it's should be cold.
There is a electric heater inside to warm the water.
It depends on the temperature rating of the hose. Cold fill hoses are rated at 20degrees, Hot at 90degrees, so the cold hose will soften and blow off.
Imagine the state of the kitchen if you go out and it does.
Seen this many times, especially with Dishwashers. I would connect it to the Cold supply. ASAP.
I would think when it rinses it will use cold water so if you use hot water that will not happen
I will ask my wife when she comes home, apparently we have one, but not sure were it is
Ok peeps,ill do it now,and Steve.......like it
Originally posted by 40inches
It depends on the temperature rating of the hose. Cold fill hoses are rated at 20degrees, Hot at 90degrees, so the cold hose will soften and blow off. Imagine the state of the KITCHEN if you go out and it does.
tis done
The other issue nobody has mentioned is that of shrinking clothing!
I had a washing machine replaced in a rental. Few weeks later the tenants complained it was using all the hot water. And they clothing was getting
smaller...
Guess what Comet/currys installers had done.....
I don't think the tenants got very far re compensation either (I managed to swerve that one and put them in direct touch with the supplier)
i know what you mean about shrinkage,any item of clothing related to my waiste has definatley shrunk
Steve![]()
Be careful Steve!!!
