I'm planning a project that would need some 1mm stainless steel plates laser cut. 180 of them. About 120mm x 30mm, one end rounded and 2 bolt holes. Is there a way to estimate the cost? For example, £45 per hour for the cutting machine with a laser speed of 5cm per second, plus the 0.7m2 of stainless sheet.
Too cheap to worry about. I had some fancy shaped plates cut out of mild steel x 3 mm. Couldnt believe my luck when he said, 30 pence each..
Each place will calculate slightly differently, including whether they have stock material and how well they can tesalate the parts. Always easiest to submit a drawing and get them to quote.
I want a guide price to see if I want to go ahead before I get quotes. If they're going to be tens of pennies each that'll be fine.
As a measure 8 plates 1.5mm, mild steel £1.5 each. 108mm diameter outside, inside 60mm ish.
