Recently had the opportunity to clear out the Sheds of an old chap in Birmingham for his family. 3 Transit Loads later including 2 FOBCO drills (I
already have one I'm rebuilding) and some quite nice rare bits and pieces, i.e. Sturmy Archer bits.
But in amongst some other bits n bobs I found this, Google isn't much help, anyone seen anything like it before?
The label reads DSWH1 in the top right hand box and volts 230/50 in the bottom left and 30 watts in the bottom right.
Early single cup heater?
Iron
Edit, I can't work out how exactly, but dowsings, with that logo made electric irons
[Edited on 22/10/14 by blakep82]
to iron what though!
Heater for a propagation tray ???
Bob
Aha what do I win.linkydink
Bob
That... is a heated bog roll holder... hmmmm
Bob
UV or IR lamp?
Its would appear to be an immersible heater element, exactly for what though?
Would appear Dowsing made various thing with electrical heated elements in them so this fits their repatoir.
Sealing wax? Something that didn't need boiling at only 30W
don't think its a lamp, the long probe bit is metallic and chromed.... oh and the wiring is far too old for me to rick plugging it in!
That Dowsing gadjee made loads of heater doodahs entering it in google came up with that patent but looking at it Dowsing didnt have owt to do with
it.
Could be a sump heater.
Bob
A willy warmer, warmer.
Reminds me of a bigger version of the heating element on my mam's old Carmen Rollers for doing her hair back in the 80s.
Early sex machine, later variants included a push pull movement.
Failing that it has a keyhole fixing on the base, is it used for heating home brew beer?
[Edited on 22/10/14 by mark chandler]
Sheep defroster, insert anusly into said frozen sheep and hay presto 5 mins later a toasty sheep.
Bob
[Edited on 22/10/14 by splitrivet]
Looks like a heater to heat up bearings before fitting on a shaft
I'm more impressed by what it's sat on. Does the other side have the timing for G45s, G50s and 7Rs? That would be even more impressive.
As they did a lot of irons for snooker tables/billiard tables etc. I wonder if it was to iron inside the pockets?
The tube does look like it would be the heater, and chromed to be smooth
What is the inside face look like when hung up on the wall?
Adrian
my guess is photographic processing, note also the 'probe' would be vertical downwards, (see keyhole slot on base/ back)
Diesel tank preheater?
Mini space heater
Glove dryer
or perhaps, an aquarium heater
It's for warming up a tin of grease to increase the viscosity and make easier to handle.
Is there no chaffing (ooer mrs) or liquid marks on it as evidence of it being used for anything?
6000 posts. Fook me, I need to get a life!
Judging by the mounting hole, it'd be mounted on the wall so the silver rod is facing the floor*, so you'd push something from below up over
the rod?
*unless that hole is there so you can secure it to a workbench etc
An early form of those machines you used to see in bars? Grip the rod and if you're hot the red light comes on?
[Edited on 22-10-2014 by Benzine]
Originally posted by Benzine
Judging by the mounting hole, it'd be mounted on the wall so the silver rod is facing the floor*, so you'd push something from below up over the rod?
Go on, put a plug on it and flick the switch...
who says it gets hot?
It might vibrate. . . .
Can it be opened to see the insides?
Condom warmer.
It is for ironing ties.
I vote sphincter stretcher.
Originally posted by adithorp
Condom warmer.
[Edited on 23/10/14 by minitici]
Drop these a line they should know what it is
Dowsing Radiant Heat Co
91-93 Baker Street, London, W1 - Head Office. Electrical Works ats Bollo Lane, Acton, London. Telephone: Mayfair 1570-1
If they are still there it was 1929
or try these guys
Cambridge Museum of Technology
The Old Pumping Station
Cheddars Lane
Cambridge
CB5 8LD
[Edited on 23/10/14 by Trollyjack]
or try these guys
Cheddars Lane
Cambridge
CB5 8LD
or try these guys
Cheddars Lane
Cambridge
CB5 8LD
Again had already found the first address but the company itself doesn't seem to exist anymore. The second address looks useful so will drop them a line.
Email with pics currently on its way to the Science Museum...
Splitrivet, was it designed by Thora Heard then???
since this is a car related forum, I think this is of interest.
from his obituary in the IEEE http://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=5315547
...After many years of working the laboratory he evolved the combined electric generator and self-starter for motorcars as far back as 1890, but
engineers engaged in the building of cars were then far too busy in concentrating upon horse-power to consider the proposition of the generator...
...After many years of working the laboratory he evolved the combined electric generator and self-starter for motorcars as far back as 1890, but engineers engaged in the building of cars were then far too busy in concentrating upon horse-power to consider the proposition of the generator...
could it be one of these...
http://www.directorypatent.com/GB/386445-a.html
A new or improved appliance to facilitate the use of sealing wax for fastening packages and the like United Kingdom Patent 386445-A
