I've been offered use of a farm building, it used to have a wooden door but that fell to bits. I need to make a new door for it. Widest point of
the frame is 9 foot, 8 foot at tallest point. All around the frame are large RSJs so I can bolt/weld to those.
What kind of steel would you use? One piece or two piece door? I was thinking of building a frame from box steel (green lines in photoshop pic) 1 or
2"? then skin it with sheet steel. I was going to make it one big door with a smaller access door (red lines on pic). What kind of hinges are
suitable and how many to use?
Doesn't have to look pretty, just needs to be sturdy and #locost
Thanks for any help
I would have it in two parts, split in the middle. Nice and simple not too heavy to handle.
Smallish angle iron 30 or 40 mm x 4mm thk frame, skinned with sheet steel/ply whatever you can scrounge up.
Hinges, 3 or 4 per side, depending on size available
[Edited on 9/1/15 by monkeyarms]
i would say split in the middle, 2" x 2" frame (or 1" with plenty of triangulation?), and skin with wood. Ply, or tongue and groove, or
slats like the rest. all steel will be heavy and expensive
was going to message you actually, was in the marina for stuff, the guy in the shop, who ive never seen before is swedish, asked me if i'd seen
this
https://www.youtube.com/watch?v=6BjI1lG2q4A
i was telling him about your amazon
I would do as you propose, although would rivit ali or zinc played steel to 1.5" box
Room for a sliding door?
If you make the door look like fort knox it will invite pikeys to think there's something of value in there and they will do what they did to my barn and just pull a few planks off the side to get in. It doesn't need to be any more secure than the rest of the walls so a timber frame with shuttering ply would do the job.
I would use 1" box section with 1" T&G boarding to skin the frame or ply. Fix the boarding from the inside with screws through the box section or better still, weld some tabs onto the box section with elongated holes (not needed if ply) to allow for movement in the timber. Maybe also use a none setting adhesive like tiger seal. Don't have any steel close to the ground as these doors will drop once hung and timber is easier to cut than steel. So keep the bottom rail 6" above the ground. I would split the opening into two with the left door 3' the other 6'. Consider running a timber across the top to keep the opening rectangular. You will need at least 3 hinges maybe 4 for the bigger door. Heavy duty hinges are available or fabricate some yourself.
Can't you square it off and use a roller shutter?
Thanks for all the suggestions! Lots of different options to think about so far
I actually think it'll be cheaper to do the door in steel,
there's a metal yard down the road where I can get scrap steel for a really good price and they have a great selection. Cost of new wood is
pretty shocking!
Beast of a car. My amazon is going to absolutely pwn that car*
