Hi all. Well this week has seen the washing machine self destruct and now the oven is playing up.
It's a beko single electric fan oven and the problem is when using in 3d fan mode whatever that is, the oven only reaches 100 degrees. My initial
thoughts were either the thermostat or an element has gone tits. However when using the oven in other modes it gets hot which kind of threw me. Only
problem is using it in the other modes you don't get the decent spread of heat and cooking dinner tonight was a right pain.
Anyone any suggestions?
Is there a separate element behind the fan for use in fan mode?
Does google throw up a wiring diagram?
Cheers chaps. Yes you were bang on the element at the back is knackered. The fan bearings were pretty sticky too so I've ordered both.
