Evening all, I have noticed my garage roof has started leaking which gives me the excuse to the Mrs to change it, it's a detached double garage
to the side of our house, What I'm trying to find out is whether I need planning permission to pitch the roof instead of fitting another flat
roof as it currently has. Next door has a pitched garage roof and I'm thinking I will be able to put a lift in if the roof is pitched.
Any advice would be greatly appreciated
Many thanks
Sam
Sadly and stupidly you will needed permission. However if you were building from scratch (not replacing) a new garage you could do a reasonable sized
one with a pitched roof! - under permitted development.(subject to a few other factors).
Fortunately it's a fairly easy application which under most circumstances will be an easy approval. Council fees would be about £172 iirc.
Thanks for reply
If neighbour has a pitched roof a planning precidence has been set.
Planners look for changes to blend in, your request to pitch the roof would include photos of the neighbouring property
I don’t see a problem
Depending where you live, and how well you get on with the neighbours I would just crack on.......unless someone complains it’s highly unlikely anyone will ever pick up on it, i built an extra garage at the last house with no problems, it didn’t even cause a problem when i sold the house.
The likelihood of planning permission being turned down for such a thing is remote. You could always crack on and then apply for planning retrospectively if someone complains. It depends on your location and neighbours.
Chap I know had permission for a flat roof, he built it to the plans and asked the inspector if he could pitch it at a later stage, he said just go on
and do it as it will better match the neighbours and do not worry about permission unless someone complains.
I would pitch it and retrospectively apply if people complain and not worry about it unless it's going to look significantly different to the
neighbours.
For the sake of £172 is it worth risking being made to tear it down?
Be aware not all property has permitted development. For instance where I live in the Waveney valley there is none you have to apply for permission
for any change to the property, although, if it would normally fall under permitted development there is no charge.
[Edited on 13/1/18 by Schrodinger]
Originally posted by Schrodinger
....although, if it would normally fall under permitted development there is no charge.
Will putting a pitched roof contravene what you can do under PD? I changed mine from flat to pitched, but it was only a small single garage and fell within the PD rules. i.e if I was starting from scratch I would have been able to build it as it is now under PD.
That makes a whole load of sense! What you are saying is if you don't have a garage with a pitched roof you can build one if compliant with pd,
but if you have an identical garage wit a flat roof you need planning permission to make the same as you could build under pd?
If you are right that is just daft.
What you are saying is if you don't have a garage with a pitched roof you can build one if compliant with pd, but if you have an identical garage wit a flat roof you need planning permission to make the same as you could build under pd?
So if the garage is an add on with a flat roof after the original house was built [or 1948] you a can change it as long as within PD rules?
Provided the end result remains compliant with PD rules, yes.
Can I pitch it???
Yes you can!
https://www.youtube.com/watch?v=O3pyCGnZzYA
Thanks for replies I'm looking into it so will keep you posted
Thanks Sam
Id crack on with it and copy the neighbours. Might be worth asking them if they had to ask the building inspector as well..
