I’m sure some of you are or have been into these…
Quite a while back I bought an GRP Enterprise dinghy, it looked quite good and the family I bought it off were currently using it. So I started doing
it up and to cut a long story short the hull had serious trailer damage to the underside that was hidden beneath the paint such that I ended up
scrapping the hull
total bummer
So I’m left with a nice set of sails in their bag (look almost new), rigging, nice alloy mast & boom… I was going to sell them but when I laid it
all out at the weekend for the photos I thought why not get another hull and go sailing in the spring? (local sailing club in Stonehaven)
I’m not very clued up on these things I but I take it I would be better going for another GRP enterprise hull? I was considering a wood hull as it
will be kept in the garage rather than outside, they seem cheaper and more roomy inside. Does what I have fit other types of dingy or just the
Enterprise?
Any advice? Thanks in advance
If my memory serves me correctly (its been a few years since i was teaching people dinghy sailing), the Enterprise was similarly sized to a Wayfarer
at about 14ft long.
Generally speaking, what you've got is probably designed to fit the Enterprise, but if you're not afraid for bit of "tinkering"
(aren't we all on here?!?) anything can be made to fit.
In terms of wooden vs. GRP hulls, seems like you just had a bad experience. Usually it's the balsa wood underneath the outer GRP that goes damp,
gets soft, and has to be removed and repaired. But the water has to get in somewhere, and some repairs are usually only surface deep, and fail rot
properly address the whole issue. Hence why epoxy resins and putty patches can usually be found in crevices for repairs. Generally GRP has a better
longevity, although can suffer from osmosis. In comparison, wooden hulls will also rot away from the inside out if they're damaged! Repair work
to both can be done, but IMO, boatbuilders nowadays use GRP for a good reason....
Lots of boats can use the Enerprise rig. I built a Selway Fisher 14' 2 berth yacht 'Deuxchevaux' with an enterprise rig. The Seahawk
17' yacht uses what is basically an Enterprise rig. It's not rocket science, if you can find a hull of up to 17' in length but more
than 14' then your rig will fit it with a bit of adjustment of length of the stays.
Have a look at https://ianhurley20.wordpress.com/about/the-ongoing-diary-of-building-deux-chevaux/
Thanks for the reply's and link. Yeah the damage to the last hull consisted of two large rectangular holes that had been punched right though and
the hull was double skinned in that area so no real access to do repair (ok someone could but I was not confident to do it)
Ok so my rig will fit many boats, that's is good to know
I realise now I may have been having a bit of tunnel vision regarding the type of
boat, I never considered using what I have on something other than a dinghy and I do like that little cabin boat in the link
I see that the parts
I already have make up a very large part of the cost of a sailboat so should be onto a winner. I'll keep an open mind when looking at a
replacement hull. Thanks
glad I asked...
[Edited on 4/10/18 by Mr Whippy]
this just ticks all the boxes, fab
I can see me going sailing from Nairn to the West coast through the loch's in something like this
Glad you like it. It was a very stable boat with lots of room inside that cabin. Useful when it rains (not in the uk of course
This was taken on Barton Broad on the Norfolk Broads. It was a very stable boat indeed and would be ideal in the lochs. I had to say good bye to it as
I became allergic to epoxy resin which it was made with - see - https://ukhbbr.wordpress.com/how-to-do-it/epoxy-a-warning/ so if you do make one be
careful.The sails are Enterprise sails made for me by Jeckells in a non standard colur if you wondered why they aren't blue.
The boat is a Selway Fisher Lynx 14 although there is a Lynx 16 which your saails would work on as well. Have a look at Paul Fishers site as he sells
plans for lots of designs.
Build your own boat for £250, I can see a book coming on.
Build your own for £250?
Originally posted by ianhurley20
I had to say good bye to it as I became allergic to epoxy resin which it was made with - see - https://ukhbbr.wordpress.com/how-to-do-it/epoxy-a-warning/ so if you do make one be careful.
