Right... here's a random question for the locostbuilders posse...
I have to replace the seal around the bottom of my shower tray - not a hard job, just a bit of a faff, but I can't work out the best sealant to
buy. I've looked at a few products, but some of the negative reviews are a bit grim. I have never had much success with acrylic sealants, so it
probably has to be silicone.
So - can anyone recommend a good brand of white silicone sealant? I don't mind paying the price if it really is good stuff, as I don't want
to be going back and doing it again in 6 months time.
Have a look at:
https://www.screwfix.com/p/dow-785-bacteria-resistant-sanitary-silicone-white-310ml/58308
Should do all you need.
Dave
Originally posted by obfripper
Have a look at:
Dave
Originally posted by Angel Acevedo
Whatever is left on the tube will go off sooner than later, so itīs better to have several jobs ready before opening.
Have a look at:
Dave
I've previously used a product called CT1, but think they've recently released a new version called BT1 that is similar in terms of mould/fungus resistance. Not there cheapest, but I've never had any issues with it.
Have a look at:
Dave
CT1, everything else is poop in comparison.
I fit bathrooms for a living and highly recommend the Dow 785 silicone. Most others will go mouldy fairly quickly.
However all silicones will tarnish over time so best to use a good mould and mildew spray regularly in the shower area. This will
extend the life of any silicone you use.
