I've got a large shed that needs taking apart. It's made of 4x2 stud wall sections with 21mm ply board sheets covering. This is a heavy
beast and very well built (can jump up and down on the roof).
Trouble is the ply has been fixed with 90mm ring shank paslode nails and I'm worried I'll wreck every sheet of ply which I don't want
to do (especially with today's prices!
Anyone got any tips for nail removal? Heads of all are visible but about 5mm below surface. Some kind of small hole saw to go round them? Borrow giant
electro magnet from the local scrapyard?
Air hacksaw might sneak between the sheets and cut the nails if access from the side is possible, or use a slitting disc into the 4x2 to only leave a
short portion of shank holding the sheet if the 4x2 is otherwise scrap, it'll deffo be smoky work though.
The hole saw idea might work if you use a plug cutter with an internal slightly bigger than the nailhead, you might need to make a guide for the
cutter to start the hole each time, they like to chatter when used freehand.
Dave
Small pry bar - will make a small hole but shouldn't ruin the board.
https://www.screwfix.com/p/magnusson-pry-bar-8-/8640V?tc=JA9&ds_kid=92700055262507126&ds_rl=1244066&gclid=Cj0KCQiAzZL-BRDnARIsAPCJs716z24F
3jXlZxElA27P8gW6QnEV6YJx0Syi4jGGWHFLA3daA-RUl90aAvjzEALw_wcB&gclsrc=aw.ds
If you have multi-cutter you should be able to cut 'between' the ply and the joist from underneath although I suspect it would be slow work
going through the nail.
I would try the small pry bar as suggested by lsdweb but I think you might be disappoined by how much damage it does- I've just attempted
something similar with T&G floor boards I wanted to remove without smashing and even being super careful I ended but with a c.20mm dent all around
the nail.
I would be very tempted by the small hole saw idea.
Let us know how it goes.
KR,
James
Bang them loose from the inside using a big hammer and piece of timber to spread the load. Cut the nail using angle grinder and cutting disc.
Sand the head off with a belt sander then knock the sheets of from inside the shed
Could you punch nail heads through the ply into the studs?
I tried doing something similar once. A multi/uni tool did about 2 nails per blade. In the end I got some long fine tooth blades for a reciprocating saw and that worked a lot better though I did snap one when I tried to bend it too much!!! Pry the wall slightly away, slip in the blade and let rip. Then bang out the nail heads and bonk in the nail shank (better than trying to remove them all!!)
Thanks for all the replies
Originally posted by nick205
A further thought...
How far do you need to strip it down?
Can you break it into sections and move the sections?
This might actually work well... roof off and then keep the 4 stud wall sections with their ply on still![]()
