Removing a house mains socket
nick205 - 27/10/22 at 08:03 PM
Need to remove a domestic electrical mains socket. Happy to cover the socket back box with a blanking plate.
Is there a recommended method?
BenB - 27/10/22 at 08:54 PM
Is it part of a ring or a spur?
Prof_Cook - 27/10/22 at 09:14 PM
Query where is the socket thats no longer needed? We had new kitchen going in and while it was a doddle for me to put a new socket in the ring further along the run, I had to get a qualified electrician in to remove the socket that had to be removed to allow a new kitchen cabinet to be installed. He used spring loaded torsion connectors to splice the ring together. He said any of the older methods risked a fire years in the future and latest specs didnt allow such things as connector blocks....
cliftyhanger - 28/10/22 at 06:12 AM
Wagos or similar
They are regarded as "maintenance free" unlike anything with screws.
Toolstation sell a 3 pole version which is handy. https://www.toolstation.com/in-line-spring-lever-connectors/p78346
nick205 - 28/10/22 at 07:05 AM
On a ring.
A qualified electrician will be doing it.
My curiosity makes me ask.
SteveWalker - 28/10/22 at 08:41 AM
Wago blocks are spring loaded and suitable for the task. However, if the location remains accessible (i.e. not plastered over or behind a new built-in feature), normal terminal blocks are still perfectly acceptable - they'd have to be really, as they are so similar to the screw terminals in a consumer unit, the round junction boxes, sockets, spurs, light switches, etc.
stevebubs - 31/10/22 at 10:17 AM
If you're just putting a normal blanking plate over the front, I would
- power the circuit off
- use Wago connectors to restore the ring
- put cover on
- power the circuit on
craig1410 - 2/11/22 at 11:55 AM
Another vote for Wago connectors to complete the ring but in order to be truly "maintenance free" the Wago box has to be closed with a tie wrap or similar through the fastening lug. This is to satisfy the regulation that it must only be accessible with a tool, in this case something to cut off the tie wrap. It's a pedantic point I know.
The other "maintenance free" option is good old crimps but only if properly made off with a proper ratcheting or hydraulic tool, not just a quick squeeze with a pair of pliers.
James - 3/11/22 at 09:34 AM
Originally posted by cliftyhanger
Wagos or similar
Thirded (fourthed?) on the Wagos.
I've been recommended them by many different electricians I know personally and they're pretty common on all the big electricians youtube channels.
I would *only* use actual Wagos (grey with orange lever) not the unbranded on that link as the proper ones are so cheap it's not worth the risk.
Now I have 3 kids (or is it just my age?!) I'm rather more risk averse and am gradually going back round my house re-wire of 2012 and improving it!
Have fun- I love doing electrics compared to most DIY jobs!
James
craig1410 - 3/11/22 at 01:50 PM
@James, yes a very good point to avoid unbranded or knock-off Wago style connectors. Even if they look like Wagos (eg grey with orange lever) they can often be knock-offs too. So buy from good sources such as TLC, CEF, Screwfix etc rather than eBay and other less regulated sources.
There is a good video by one of my favourite YouTube electricians here: https://www.youtube.com/watch?v=G9JTBTrcDSE
John Ward is a bit of a legend in the electrician online community and has a dead-pan but razor-sharp wit that I really enjoy, not to mention decades of experience. As he says in the above video, "...these are direct from China and made from solid Chinesium..."
Interestingly, the knock-offs he tests in the video perform pretty well but the wider point he makes is still valid - that you don't know from one batch to the next what quality level you might get unless you buy via a reputable supply chain with appropriate ISO and other QA methodologies in place.
In other videos by John, he tests various connector types to destruction using current from a welder and these show just how much overload these things can take (not just Wagos) when used correctly.
