As above thank you
Is that an O2 sensor removal tool? They usually have a gap in the socket for the wiring.
Hmm, on closer inspection it looks to have a square jaw and what looks like rubber padding. Maybe not an O2 sensor then...
jacko
Any clues: Automotive, plumbing....(I ask, because I know many folks organise their tools in groups according to tasks).
My guess would be a plumbing tool of some kind for tightening/loosening a fitting on a tank. Although, as Slimy38 points out, it's got padded
sections in the first opening. Perhaps to stop it damaging a softer part.
Given your Dad was able to help with the car bumper, any chance it's a tool of your Dad's. Someone of his generation may know what it's for.
I’m sorry I have no idea what it’s for dad has never see it
I have a plumber mate I will ask him if he knows
G
Ps sorry about the size of the picture
[Edited on 31/3/23 by jacko]
Smaller image
well it seems to fit over a hex but have a slot for something such as a pin above that hex which does not rotate when you use the in either direction.
Apart from that, I can't think of anything
Fellow petrol head suggests a locking wheel nut key of some kind. Not seen one like it, but you never know.
I love these kind of posts! It gets the tired old brain working again
Could it be an injector removal tool?
Ignorant lot - it's a doodle-dang-thingy
Heathen........It identifies as a thingy-me-jig
Clearly a Whatsamicallit
Any progress on what this tool is?
I've asked a couple of guys at work, but no ideas here.
Maybe a tool for tightening or removing something, with the slot allowing an attached cable to be kept out of the way?
I did an image search using yandex
and found
sprinkler key
https://01-shop.com/katalog-oborudovanija/vodyanoe-pozharotushenie/tyco/sprinklers-acessories/accessories-sprinkler/kljuch-sprinklernyj/
so its a sprinkler accessory
translating the page
translated page
indicates it is for
"Designed for installation of TYCO sprinklers models TY-B / TY-FRB on the pipeline of an automatic sprinkler water fire extinguishing
system"
[Edited on 4/4/23 by gremlin1234]
Well now we know what it is, but not why the slot is there. From the looks of the nozzle that it for screwing and unscrewing, a simple square hole, like a radiator key, would do the job and the tee-slot seems redundant.
Well, glad that's resolved!
Info passed on to my work colleagues so they stop wondering
It allows the the disc on the end of the sprinkler in/out....
most of my research is usually local history, nice to have a different challenge.
so in summary
it is a tool for tightening (fire) sprinkler heads into recessed fittings.
I'm betting that many maintenance people just use an open-ended spanner though!
and found
sprinkler key
translated page
indicates it is for
"Designed for installation of TYCO sprinklers models TY-B / TY-FRB on the pipeline of an automatic sprinkler water fire extinguishing system"
