Hey chaps
Any builders or plasterboard experts on here?
I am trying to find a solution to a wall where there isnt enough joists to get 2 plasterboard sheets to meet properly and allow fixings to ensure they
sit flush with each other.
Imagine 2 plasterboard sheets...the bottom sheet and the top sheet share the same vertical joists at each end. But the horizontal, where top and
bottom meet, there is no room for a joist. The top and bottom edge dont line up because of this.
Does anyone know of a way to make these edges sit flush and allow plaster over the top?
I was thinking of thin metal sheet behind and screw into it on the bottom and top sheet to pull them flush.
Anyone ever had this issue and overcome it?
I will add an amazing drawing for reference. The red area is the part that needs sorting....
could you get a larger sheet of board?
Realistically the only safe way is to add a complete joist. Don't try and use a fixing to hold two boards together, all you'll be doing is
making a nice flexible wall that will have cracking plaster in no time.
Plasterboard doesn't like large spans, we've found anything more than 450 is just asking for trouble when it comes to skimming. Even 450 is
too wide if the joists aren't a decent thickness.
[Edited on 10-6-23 by Slimy38]
If there's nothing behind the boards, just put a bit of timber to screw them both to. It doesn't need to be a, full joist. If it's going over existing plasterboards, stick it down with some pu adhesive foam. Scrim tape over the join will help prevent cracking.
The plasterboards should be fitted vertically and each long joint should be fixed to the studs.
If this is how it's going to be and you you can fit steel behind then why not nog between the studs with timber.
Thinking further...
My house is timber framed and plasterboard lined. All the wall plasterboard sheets are fitted vertically. In places where the vertical studs
aren't in exactly the right place extra vertical studs have been added - to support adjoining plasterboard sheet edges.
I'm a carpenter joiner by trade and much of my site work in the early years was stud work.
It is not hard to work out the centers for each stud so it meets all edges of plaster board.
I think the Regs have changed so that all edges have to be carried by noggins like where ceiling boards meet external walls, it has to be nogged
between the floor joists.
I think we need to ask what he means by 'no room for a joist'. If there's 20mm, put a sliver of timber in to bridge them. Doesn't
need fixing to anything else. If there's less than 20mm, use the pu plasterboard adhesive foam from screwfix. It's basically expanding foam
that doesn't actually expand.
This would appear to be a DIY project, rather than a work of artistry.
