http://www.altiss.com/
They do bike carbs to car engine manifolds from £180 which is what i'm interested in.
I was going to ask the same question after reading about them in PPC.....
Nice set of 42mm BB carbs waiting to mate with my XE.
Only issue I have is who can jet the carbs ? I live 100's of miles from Bogg Bros...
there's an article in this months PPC mag on bike carbs and Altiss manifolds. From the picss the ali welding looks good, but it would be
wouldn't it. However if your using a Zetec, then the stub manifold from a ST170 Duratec (zetec in disguise) will fit Suzuki bodies straight out
of the box. According to PPC at least.
[Edited on 1/9/05 by Jonr]
When i bought my 2nd hand kit it came with 2 litre Zetec and ZX9R carbs so i may aswell use them.
All they require are the carbs and the inlet manifold gasket in order to make the manifold.
i was thinking about this too, using some bike throttle bodies. i recon you could make a manifold yourself quite easily. there is some ally welding
stuff that has been mentioned before that you can use with a blow torch with good results, can't remember what it's called but someone must
remember. then its only a matter of sourcing some thick ally plate and relative sized tubes and make the head plate from an inlet gasket as a template
and match it to the head, then cut the tubes to fit and voila (easy as that he says!).
Ned.
Ok smart arse make one for me!!
Originally posted by Surrey Dave
Ned- yeah its easy!!! , takes bloody yonks though........
Funny how all this bike carb stuff is sprouting up all over the place
I dont mind taking a bit of Trail blazing credit down south!!!!
StuartAinslie; If you ring around quite a few bike tuning firms have car rolling roads....
You answered the post before I made it!!!
Yes the lurgy has nearly gone, that was one mean lurgy!!!!, could be there Sunday
Credit where credit is due Dave....... BUT!! you can't take credit for me going this route as the kit came with the engine and carbs and the chap
was going to di it to his engine
Make sure you go Sunday so i can have a peep at your setup.
Child !!
Damn your eyes!! Damn your britched
[Edited on 1/9/05 by donut]
i have enough thick plate and tube for 2 manifolds i may be willing to part with one lot for the right price i will be making a manifold for my gsxr 750's to ecotec
U2U Sent dear chap
Dam, too slow !!
Jason
if i did make a manifold it would be for bike throttle bodies and would likely be fitted toa peugeot 106 i already have very expensive direct to head jenvey bodies for my vauxhall engine
Snob!!
Hi Guys
Excuse the ignorance but what's PPC magazine? Could somebody scan the article?
If I don't sell my complete Zetec, I'm going to throttle bodies and need to weigh up the options!
Regards
Wyn
ppc is practical performance car. get into your decent local new agents early in the month to get a copy, or better sill subscribe.
http://www.ppcmag.co.uk/
Hi guys
I can't seem to get a copy anywhere - could somebody copy the article on building your own fuel injection?
Regards
Wyn
i have a scanner and a full set of ppc
u2u me I scan engineering drawings every day in work, does come in useful sometimes
Hi Liam
You have U2U.
Regards
Wyn
