using compaq 3800 for sat nav?
skydivepaul - 2/2/06 at 08:43 PM
I have a compaq PDA 3800 266Mhz 64MB ram with a 128Mb SD card. I was going to buy a tomtom1 but have been thinking about using the PDA for the sat nav. I only use it as a posh calender and address book at the minute so none of the memory has been used up.
Has anyone used these for satnav and are they any good. I have been given tomtom maps for the PDA on a CD so i only need the cradle and GPS receiver.
I saw this on e bay linky.
Any comments or ideas would be appreciated
ecosse - 2/2/06 at 09:52 PM
I use a laptop, Autoroute and a GPS mouse similar to the one in your link and it all works well.
I've not used it with a PDA but I've seen a few of them and it seems to work well
Lots of info here if you have not found it already
Alex
RazMan - 3/2/06 at 08:55 AM
I used to use my 3850 with a GPS jacket and it worked very well with both TomTom and Navman.
I used a windscreen mount as the unit is quite heavy and will break the air vent mounts.
I have since bought a Navman 520 because I found that I was only using the Compaq for GPS work and the dedicated units crash less frequently and generally do the job with less fuss.
skydivepaul - 3/2/06 at 09:34 AM
Thanks for that, I'll be using the sat nav for probably 2 - 3 journeys a week as most of the time i know where i'm going.
whitestu - 3/2/06 at 10:51 AM
I also use TomTom on a 3850 - works brilliantly.
You'll probably need a 256Mb card to get all the maps on though.
Stu
stevebubs - 3/2/06 at 11:59 AM
You'll be fine with that setup....
RazMan - 3/2/06 at 12:41 PM
Just noticed the price is rather high - you might want to look on eBay for cheaper options (also self powered)
http://cgi.ebay.co.uk/GPS-Antenna-Aerial-Amplifier-MC-MCX-MMCX-BNC-SMA-SMB_W0QQitemZ5858620348QQcategoryZ4668QQrdZ1QQcmdZViewItem
