tin top question
Donuts - 15/6/06 at 07:10 PM
I have a pug 306 with a broken handbrake cable, how do you detach the cable at the wheel end?
any help most apretiated
ps. getting married on sat, at mother in laws, left haynes manual at home. need handbrake running......hmmmph
cheers
dunc
andybod - 15/6/06 at 08:21 PM
discs or shoes at the rear if it.s discs easy unclip from caliper if its shoes remove drum remove shoes and strip that way cable normally needs a little tap to remove from drum back plate
andybod - 15/6/06 at 08:23 PM
sorry where in derby are you i'm in swadlncote if you get stuck give us a shout
Donuts - 16/6/06 at 08:26 AM
I live in derby, unfortunatly I am in milton keynes where I am getting married.
its discs.
the outer apears to be attached to a plate, and the inner goes through and clips onto the lever on the caliper. how do i get the outer off. or can i replace just the inner?
andybod - 16/6/06 at 06:21 PM
should be a circlip or e clip around the outer cable this will ned to be removed first then the cable will probably be seized into the housing use a drift to tap it out or call the aa/rac they can sometimes replace the inner cable as a temporary repair only helps if your in the aa/rac though
