There are two small plastic pipes that just push into the bottom of the plastic petrol tank on the strimmer I have borrowed.
Problem is that one of them drips petrol out.
Anyone any suggestions to get or make a good seal?
Ta,
Pat...
Just use it quickly and gve it back!
Or put a jubilee clip on it.
Nothing to jubliee around.
The soft pipe just psuhes through a hole in the bottom of the tank and sticks up inside the tank a couple of mm.
A bolt on nipple may be a good solution if you can get such a part ???
Pat...
Might find something useful like a bulkhead connector in a Model shop if there's one anywhere near you.
Can we not replace the pipe It may have age hardened and cracked. It's been sat in the garage for 5 years at least
Carl
Did PTM make it?
