Preferably with basic mechanical skills. Nothing too tricky - I just need to adjust my pedal linkages. The frustrating thing is that I can just about
reach them with one finger but can't adjust them without removing the dash and steering wheel (which I will probably end up doing)
All interested applicants please apply here - dwarf sized beer tokens available
i have the same problem fiddling with balance bar stuff.. lanky git + tiny space = seats and steering out every time
I've always had problems changing cables and could never quite get at the pedals.
I knew this would be a problem with the build so I rivnutted the scuttle panel to make for easy access. Good job too, as I snapped my first clutch
cable.
Got a small child you can borrow (can post)
Originally posted by rjs
Got a small child you can borrow (can post)![]()
When fitting a new throttle cable to my old Indy, I ended up with my legs dangling over the rollbar and the back of my head on the floor looking up at
the pedals.
Hurt a bit, but needs must.
I can lend you spencer if you like??
He's very good at mechanics (see my web site)
[Edited on 13/10/06 by zoom]
I cut the tray above the pedals and Rivnutted it down.
I just fixed a bit of Angle to support the loose end, and secured with Rivnuts. Its a bit of a tug to pull out, but isnt too difficult. Its a darn
sight easier than trying to work upside down on your back and over your head in a confined space. I'm 5' 10" and not 20 Stone
I just
cant get in there to do it.
Split Battery Shelf 1
Split Battery Shelf 2
Split Battery Shelf 3
That Spencer's got some talent!! Did confused by his choice of pedal placement though for his paws?? Placement seems to look more human like?
