as above realy is it possible ?
Your PC hides the film somewhere on your hard drive, i think in a temp file but not sure where but it is possible.
Tools -
<www.keepvid.com>
SUPER
and a DVD authoring and burning software like Tmpgenc DVD Author or NeroVision or Ulead DVD Workshop.
Guide -
Download video with <www.keepvid.com>
1. Copy the link(http url) from the page with the Video
2. Paste the link into <www.keepvid.com> input box and hit download and waaaaaait
3. Right Click on Download Link and select Save Target As
Convert with SUPER -
1. Right click in SUPER to open the file you just downloaded, Add Multimedia File(s)
2. Select vob DVD Compliant under Select the Output Container
3. Set Video Scale Size, 720x480 for NTSC or 720x576 for PAL
4. Set Aspect to 4:3
5. Set frame/sec, 29.97 for NTSC or 25 for PAL
6. Encode
( If you want smaller output file size lower the video and audio Bitrate, you can calculate the bitrate and output file size using a bitrate
calculator like <www.videohelp.com/calc> )
Author and Burn -
Add the DVD VOB file in for example Tmpgenc DVD Author or NeroVision or Ulead DVD Workshop and author and burn it to a DVD.
You can also use firefox as browser with the videodownloader plugin. Supports 60+ different video websites.
www.videodownloader.net
Yes as above, use firefox as your browser and then download an appropriate video saver utility plug in.
There is a site out there that does it. cant remember the link but ive covered it b4 on here do a search and the instructions are there
thanks will have a play later
