New job need a new PDA, I think it's about time I retired my old BW Handspring visor, had a look at the Dell X51 and there are so many
Ipaq's any thought guys?
The only real need is wifi. a colour screen would be a bonus
Regards
Mark
My old IPAQ 3870 was excellent and only got retired when I bout a phone/pda as an attempted replacement
didnt work
Ive used 9500, 9300, O2's XDA exec all of which were good in their own respects (except for the XDA which was quite frankly W*NK) and now I used
Oranges SPV M600 but very rarely as a phone to keep the screen from clogging up.
I'd recomend ether the IPAQ range (no help sorry as the 3870 is obsolete) or the SPV M600 (but only if you needed phone facility as well)
I'm using an X51v at the mo. Excellent product - gets used for sat nav too. I've got the VGA cable too so you can run presentations etc on a
projector. The video reproduction is pretty good and the VGA screen better than most. Wifi and bluetooth built in - dead easy to set up.
Also has a CF slot and SD slot - useful for transferring photos from the digital camera.
My god - sounds like I'm a Dell rep!
I would check if you realy want to go the Microsoft route. A few people that have had palm's can find the Microsoft PDAs a little limited, might
be an idea to borrow one for a while..
Some of latest Palms have WiFi..
Dan
life drive is the way forward
Originally posted by Marcus
I'm using an X51v at the mo. Excellent product - gets used for sat nav too. I've got the VGA cable too so you can run presentations etc on a projector. The video reproduction is pretty good and the VGA screen better than most. Wifi and bluetooth built in - dead easy to set up.
To be fair, until the last software update (about July last year) I had more problems with the thing freezing and not starting up - I nearly went back
to my Palm Tungsten T2!
The early WM5 was crap. Now I wouldn't go back. The convenience of dragging and dropping word, powerpoint and excel files from the PC cannot be
understated IMO.
Dell's SAT NAV aint too shoddy either (other than not being able to load speed camera locations)
One of teh new xda's has GPS built in. Would recommend the exec if you dont mind a slightly larger pocket!
The newish HTC3300 handset is a phone/pda/gps/wifi all-in-one. Looks pretty good if you want a phone - on contract with O2 as the xda orbit.
