kettle question
mookaloid - 4/3/07 at 05:12 PM
My electric kettle has just given up.
I had a whistling kettle stored away which I am now using on the gas stove
Queston is which one is cheaper to run?
Should i bother buying a new electric kettle?
Mark
flak monkey - 4/3/07 at 05:21 PM
You need to know how much a kWh of electric and gas costs, then you can work it out
The info will be on the back of your last bill
[Edited on 4/3/07 by flak monkey]
mookaloid - 4/3/07 at 05:36 PM
I was hoping one of you university types would have studied this stuff.....
I am also sure that it is not as straightforward as which fuel is cheapest per KW as the different methods will have different efficiencies. eg a lot of the heat from the gas cooker will escape up the sides
The meters are not accurate enough to measure how much is used for each method.
Mark
mookaloid - 4/3/07 at 05:37 PM
Originally posted by chris mason
i would say the gas kettle is cheaper to run, but it takes far longer to boil than an electric one. so stop being tight and buy a new one
Chris
Cheers Chris
Danozeman - 4/3/07 at 05:39 PM
They take too long. It would be a close call i reckon in cheapness. The new kettles take no time at all too boil where as the whistlers take an age.
My leccy kettle takes no time at all to boil when nearly full so i know which id rather when i was gagging for a brew,.
[Edited on 4/3/07 by Danozeman]
Peteff - 4/3/07 at 05:48 PM
We have a quick boil gas kettle which takes no time. The main point is don't put more water in than you need and it will save time and money.
DarrenW - 4/3/07 at 05:48 PM
You would probs never be able to work out which is cheapest for you unless you have a water dosing system that is calibrated to cup sizes so you can optimised the water heated : water needed ratio.
Your other option is to only drink cordials and therefore ne need for a kettle at all. Or just go to the pub instead......
ch1ll1 - 4/3/07 at 05:54 PM
SAVE LOADS
every time you fancy a drink call round at your neighbours house
JoelP - 4/3/07 at 05:56 PM
heat it over an open fire, then its free.
ruskino80 - 4/3/07 at 05:57 PM
mookaloid - 4/3/07 at 06:06 PM
I don't know - I ask a serious question and all I get is daft answers
escort_innit - 4/3/07 at 06:43 PM
If you live somewhere where your kettle scales up quickly stick with the stove top one as it will survive longer as you can clean it more easily. Then you don't need to buy new ones as often, saving money that way.
The most fuel efficient way (and therefore cheaest) of using a kettle is only to put as much water in it as you need to use instead of filling it to the brim each time.
The most fuel efficient way (and therefore cheapest) of using a kettle is only to put as much water in it as you need to use instead of filling it to the brim each time.
billynomates - 4/3/07 at 06:46 PM
Cup full of water in the microwave.
SixedUp - 4/3/07 at 07:32 PM
Although this will be quite efficient, it will tend to be slow, as most microwaves are only 800w, rather than the 3000w of most kettles. However, if you do this please please PLEASE put a non-metallic stirrer in the cup at the same time. This will stop you producing a cup of super-heated water (water that is substantially hotter than boiling).
The problem is, you add something (coffee powder?) to the super-heated water and it can practically explode out of the cup. There have been some very nasty scalds produced like that
Richard
