has arrived
its got a 16.5 litre V12
and 8 wheel drive.
thatl sort out the numpties on the school run
er... eh?
How many gallons does it do to the mile?
. My mate George used to run a V8 air cooled Maggy Deutz diesel 6WD recovery wagon, if it sounds as nice as
that it will be cool.
[Edited on 24/4/07 by Peteff]
does 4mpg unladen apparently
its a tatra 813,google it
Tatra T815-24VV96 8x8
Technical Specifications
PURPOSE
The chassis-cab, heavy-duty vehicle designated for hard terain, difficult climatic and environment conditions. The unique chassis and suspension
design gives the vehicle exceptional resistance to shocks and vibrations, protects superstructures from torsion and stresses and allows to be driven
fast on rough roads.
ENGINE
Type: Tatra T3B-928.40
Air cooled, four stroke turbo-charged and charge-air-cooled direct injection Diesel, EURO I
No. of cylinders: 8
Bore/stroke: 120/140 mm
Swept volume: 12667 cm³
Power: 270 kW/1800 rpm
Max. torque: 1670 Nm/1200 rpm
TRANSMISSION
Clutch: Tatra MFZ 1x430
single plate
Transfer Case: Tatra 2,30 TRK 1,1/1,8
Speed reducing, two speed, shifted on a halt. Pneumatic control.
Gearbox: Tatra 10 TS 140 synchromesh
10 forward / 2 reverse
DIMENSIONS & CAPACITIES
Width: 2500 mm
Lenght: 9280 mm
Height: 3240 mm
Clearance: 390 mm
Kerb weight: 14900 kg
Payload max: 15000 kg
GVW: 29900 kg
Trailer weight offroad: 20000 kg
Trailer weight onroad: 65000 kg
PERFORMANCE
Top Speed: 85 km/h
Gradeability: 100%
Climbing ability-vertical step: 500 mm
Climbing ability-trench width: 2000 mm
Fordability: 1200 mm
Turning circle diameter: 27 m
Cruising range: 1000 km
Fuel tanks Diesel: 420 liter
WINCH
Self recovery winch with rear, front, and side output of rope.
Nominal pulling capacity: 118 kN at 25 m
Rope lenght 83 m
ELECTRICAL SYSTEM
System: 24 Volt
Batteries: 2x 12V 180 Ah
Alternator: 28V / 80A
TYRES & RIMS
Tyres: 15.00 R21 TT
Discs: 11.25 - 21 split rims
BRAKES
Dual circuit pressure-air brakes, acting on wheels of all axles, wedge type self-adjustable brake units.
Cool. Anything with a fordability in it's spec is OK with me!
Mike
[Edited on 24/4/07 by Guinness]
thats the wimp V8 version
"184kW @ 2000 rpm and 960Nm @ 1200 rpm" power is a bit low but my god look at the torque
will you ever do much driveing in it?
Got any photo's
sweet!
but why?! i mean, i'd love one, but what would you do with it?
Do you do trialing for big boys? Those buggers will go up the side of a house.
It used to be on telly on Sunday afternoons. Mental.
Edit Must learn to spell Sunday.
[Edited on 24/4/07 by Confused but excited.]
oh my god £400 to fill that with derv
ill get some pics morra if i get time...its not registered yet as its a Czech import...you know what the dvla/vosa are like.
its for carting a drilling rig around,no doubt i can find some mud to play in
[Edited on 24/4/07 by theconrodkid]
27metre turning circle! It's a good job it'll drive straight over roundabouts.
2 reverse speeds!
Change up going backwards. Cool
Simon
Where are you drilling?
15ton payload, now that is cool. I need to find a job where i need one of those.
WE NEED TO MAKE A LOCOST VERSION OF IT
[Edited on 24/4/07 by JoelP]
Is there anything you can't buy on eBay?
Tatra 813
Why, oh Why????
What are you going to do with it?
Handy for getting the car to the shows I suppose. Wish I had one. Doh!
[Edited on 24/4/07 by coozer]
them things have 2 starter motors
S'pose you could use it for squashing LSIS's & Furore's!!
Thats cool!
but "Mechanical Cruise Control" I'd be about scared about that.
Visible smoke test anyone?
Mike
managed 1 crap pic before the battery in my camera went flat,last one in my archive
nice piccie jon, glad to see you've got a nice cuppa
http://www.locostbuilders.co.uk/upload/000_0139.jpg
that truck reminds of the virbrosis trucks used on land for geo physics.
they literally have rams that thump the truck up and down to make a sesimic signal that can be transmitted through the earth and reflected.
they weigh approx 30 tons!
cool, so then your using this to take the kids to school...
white van man will give one of these a wide berth MAYBE
Perfect for commutting in London were I work. Nothing would cut me up or get in the way and if they do just drive straight over them!!!!!!!!
