according to my Polish friend he drove himself from the hospital and will be racing next week,tuff stuff?
With a broken leg?? Even with a hair line fracture it hurts like hell , doubt he will be allowed to race
I think the broken leg turned out to be a twisted ankle, Nothing like the media to blow things up eh?
"BMW Sauber’s Robert Kubica has escaped serious injury after crashing heavily in Sunday’s Canadian Grand Prix. Kubica suffered a light concussion
and a sprained ankle in the high-speed accident."
Steve.
[Edited on 11/6/07 by stevec]
"BMW Sauber’s Robert Kubica has escaped serious injury after crashing heavily in Sunday’s Canadian Grand Prix. Kubica suffered a light concussion and a sprained ankle in the high-speed accident."
Steve.
Broken leg or no broken leg.
My heart sank when I saw the second impact in slow-mo.
I know the first was a big hit but all the crumple zonenes and safty tub seemed to do there job.
The second impact with no impact zones left looked hard I know the Hans devices will have assisted but it still seemed a huge amount of head and kneck
movement. Especialy as they seemed to be a long time assesing him before removing him. But if he was coherant and breathing ok I suppose they were
checking that they wernt about to rush to get him out and cause further issues.
Not an expert just my ramblins by the way
Anyway glad that he has come out unscathed a testiment to the F1 doctors and safty designers
regards
Agriv8
Steve.
Not so much the medias fault for once!![]()
The broken leg announcement, came from the medical centre at the track, at the end of Sundays race.......and I believe......(could be wrong on this bit...)....confirmed by the BMW Sauber pit side.....at the end of the race....
I think that once Rubica had been taken to hospital at Montreal, and more precise scans were performed, it was happily discovered that there was no break.
Even more of a miracle methinks....![]()
Fozzie![]()
Who is Rubica?
Gosh, that's puzzling.
Ian
My first thought was that he was checked out by Quebec doctors in hospital emergency. They told me my head was OK after a car accident too - scans the
lot - but I was not OK, which was confirmed by three doctors later (including a neurologist) who confirmed post concussion syndrome. I still get
frequent migraines which I never had before.
The moral of the story:
No such thing as a "slight concussion".
Originally posted by robinbastd
Who is Rubica?![]()
Ian
is it just me or did someone instantly remember senna's crash after seeing this one?
not only that, i havent seen such a crash since Roland Ratzenberger's one the day before Senna.
Tells you something about two things:
1. God
2. the incredible advance in safety in F1 concerning CF monocoques and how they can save a man's life from a head-on crash at probably more than
120mph
Got to agree with Agriv8 there, first thing I said when I saw Kubicas' head going side to side...was.... I thought HANS was supposed to prevent
that....... but so glad he had it anyway!
and yes......thoughts of Senna were immediate too
Fozzie
I think without the Hans device his neck would have been broken & yes, it was horribly reminiscent of the Senna/Roland Ratzenburger incidents. Modern F1 = very strongly built!
The HANS device is designed to limit the forward movement of the head, not the side to side. If u watch, f1 driver still lean there heads in to the
corners with the HANS device as much as they did before!
i also thought that his head moved from side to side a lot and i think they should maybe bring the cockpit side "cushion" a bit closer
together or look at other ways of limiting side to side head movement.
What I found disturbing is that there were no ambulance cars around the whole time. Just 3 or 4 normal cars, including the safety car if I remember
well... Where was the ambulance? I would have thought they are supposed to be on the spot quicker than that.
But very lucky boy that Kubica...
Gergely
Originally posted by Hoodie_Alex
i also thought that his head moved from side to side a lot and i think they should maybe bring the cockpit side "cushion" a bit closer together or look at other ways of limiting side to side head movement.
There's only so much they can do to limit movement of the head - still need to turn their heads to actually drive the cars. Maybe they can afford
to restrict movement of the head more on a gently curving oval track than they can for an F1 driver going around Monaco.
The safety in F1 these days is incredible but there's only so far they can go in its pursuit. Cant alter the fact that a car hitting a solid
object at 150mph is going to cause injuries - the fact that its a sprained ankle is testament to the advances made.
Originally posted by Paul TigerB6
There's only so much they can do to limit movement of the head - still need to turn their heads to actually drive the cars. Maybe they can afford to restrict movement of the head more on a gently curving oval track than they can for an F1 driver going around Monaco.
The safety in F1 these days is incredible but there's only so far they can go in its pursuit. Cant alter the fact that a car hitting a solid object at 150mph is going to cause injuries - the fact that its a sprained ankle is testament to the advances made.
It would be tricky to make the head padding any closer to the head because then you limit the cockpit opening making it harder to get out in an emergency.
1. God
2. the incredible advance in safety in F1 concerning CF monocoques and how they can save a man's life from a head-on crash at probably more than 120mph
Well 1 doesn't exist other than in the imagination does he?
OK I'll get me coat - takes cover
For all those who didn't see the crash see the link below. The second clip shows the shocking speed at the point of inpact not seen on the TV
footage.
Crash vid
Carl
Could be wrong but Im sure in the prerace buildup Brundle said they go from 185mph 6 gear to 30mph 2nd gear for the hair pin. Puts a bit more speed on it!
To be honest - once he'd hit the kerb and taken off he was just a passenger...
One hell of a smash, and amazing that he survived relatively undamaged.
