In tintop, flooded roads all the way home, tried the shortcut, looked do-able (checked afterwards was only 10" ), forgot about the small dip, car
coming the other way with a big bow wave, mine's a diesel and .... dead.
Strongly suspect hydraulic lock but hopefully only a drop in it so may get it fixed without major drama. Company car thank bigG so all covered
but supposed to be going on hols with it next week
Luckily missus had been through the same patch just 25mins before and not got caught (neither has a low air intake but hers is lower than mine).
MORAL: Go the long (dry) way.
p.s. Was fed up enough with this weather not being able to drive the kit...
[Edited on 26/7/2007 by NeilP]
But you're not as big a plonker as the bloke who was driving the one I just fixed, a tractor with the air intake nearly 4' off the ground
but he still found some water deep enough!
Injectors out & water drained off the bottom of the sump & we spun it over. The water hit the workshop roof with some force but there were no
nasty noises. Injectors refitted & it ran sweet as ever, lucky escape
Sorry to here your troubles we had the same in Hull to much WATER not long back
Jacko
Compared the problems people have had and are having elsewhere in the country and esp. the family of the guys in Gloucester a damp car is really nothing...
I drove home tonight, and not even a puddle to drive thru
bummer !
i even went the long way just in case
[Edited on 26/7/07 by steve m]
