Hi any ldv technicians i need help i have an 02 plate pilot and have just done the clutch on it now the check engine light is on and it runs like a nail had to disconnect the crank sensor is there a reset device to clear its memory cheers Rick
U need a diagnostic machine to clear it but it shouldnt need clearing. Are you sure its connected ok and lined up ok??
They can be easily broken as they is in an arkward place and the pins pul out of the plug. (I speak from experiance.) Post office mechanic.
[Edited on 21/8/07 by Danozeman]
thanks for that will check for damaged pins tomorrow
Crank sensors get damaged no matter how careful you are.
With Rover cars it usually often dosen't show up until a couple of months later.
