Can any one tell me where the fill level is positioned on the green westfield reverse box there is a small drill hole positioned three quaters away up
not sure if thats it.
regards mick
There are 2 round knurled plugs on one side, both with allen key drives.
The topmost one of those, fill to level with the bottom of that plugs hole (ie. till it just comes out).
From memory (it does state it in the manual) its 185ml.
Cheers for that
do you find that it leaks a little oil from time to time
There's a really small breather at the top of the front input bearing housing.
Most of them will pee out oil here. Its common to drill that out to fit a solid brakepipe section to it, then a small expansion tank above it so it
can drain back.
I'm going to try a small syringe on mine instead, sometime.....
