any one else had this problem?
got one sky plus box, and one normal box, multi room set up, both boxes on 1 satalite.
http://bebo.com/watch/4784370262
^ link for a video of what it does
this is the sky plus box. just stops and starts all the time. can't be the signal as the other box is fine (well, was, as it was until last
night, now it says no satalite signal, but the sky plus isn't any worse
I have no answers I am afraid, but I sypathise with your annoyance...
My sky plus does the same. Virtually guarentee that everything that is recorded has a chunk where the audio is choppy and doesn't match the
video... Very frustrating!
I also get where you hit plat, it runs for 5 seconds then locks up. Have to stop and re-start the playback to get it to work...
Mark
exactly, stange thing is though, it records perfectly.
We've got a Virgin V+ box and they're b*llocks too - got 'upgraded' about 5 months ago when we moved house and I think we're
on our 5th box now and this one is going tits up as we speak. Most Discovery channels either don't work or are extremely pixilated but
they're fine on the original box from the old house we now have in the bedroom on the came cable connection...... The only good thing is Virgin
just come round and give us a new box now no questions asked BUT you loose all your recorded stuff every time
cant say who I work for but you will find the problem is at the back of the box with the f connector.
The center core is not big enough to give a good mechanical connection to the mounted female f con.
u2 u me and I will send you an adapter FTCOP
With my sky, the picture and sound keep going slightly out of sync recently. Anyone else had this problem?
mine has been doing that too. only noticed it since we got a 40" LCD, and didn't notice on the 28" CRT one. we just put it down to the new TV
The connections in the plugs are a push fit, not a soldered connection anymore.
Thus, chocolate fireguard springs to mind.
yeah, they had some electric tape to help, but with the heat they make the glue just melted
sony telly?
