Reseting House Alarm! (9800 Model)
mackei23b - 24/9/07 at 11:55 AM
Hi there
Hopefully someone can help. How can I reset a 9800 Alarm back to the default settings as I've lost the alarm code.
Many thanks in advance!
Ian
skydivepaul - 24/9/07 at 12:03 PM
pretty sure you turn off all power, battery and mains. take out the small NVM eeprom 8 pin? power up with the eeprom out and then replace it once powered up.
that should reset the code and all other parameters. you will have to set up all the circuits again though.
i have the manual at home if you get stuck
cheers
Paul
joneh - 24/9/07 at 12:07 PM
Have you just broken in and need to turn the alarm off?
ernie - 24/9/07 at 05:22 PM
Do not remove eprom. will check in workshop manual and post laterTextText
mackei23b - 24/9/07 at 07:50 PM
Many thanks
Now sorted.
Ian
