will this work
mangogrooveworkshop - 4/11/07 at 04:40 PM
http://www.liveleak.com/view?i=8b9_1193832262
ceebmoj - 4/11/07 at 05:17 PM
yes it works however obviosly only in cirys that have the emergancy bi pass system witch I currently beleave to only be in the USA if you have alook on some of the hacker web sights you will see that some of the codes are published so you can buils an IR transmitter lod on a code file and away you go.
joneh - 4/11/07 at 05:22 PM
LMAO. And the code happens to be 911 on a philips universal remote. What a load of b***ocks.
BenB - 4/11/07 at 08:37 PM
The technology works (ie hacking traffic light sensors) but 9-1-1 as the manafacturer code working with all remote controls. Jz...
