VAG COM
carlgeldard - 6/1/08 at 07:33 PM
Anybody used VAG COM. I need something to reset the airbag light on a Skoda Fabia VRS.
VAG COM Link
Carl
ko_racer - 6/1/08 at 07:48 PM
I use it all the time, works really well, you need to be very carefull with VAG com and air bag modules, it can knacker them as there is a bug in some airbag modules firmware. The website tells you which modules are afected. Best bet would be to get a friendly dealer to do it. Shouldn't cost a lot.
bassett - 6/1/08 at 07:51 PM
Strangely did this, this morning on my mk4 golf gti. Bought a Gendan Automotive fault code reader for about £40-50. Really good and also after reading codes the 3rd time will also erase them. If you get one dont plug it in with an aftermarket stereo.
Adam
GregSL75 - 6/1/08 at 08:05 PM
Basset, out of interest what OBD software do you use with your Gendan?
I'm using Scantool.net for all my Euroboxes, seems to work well.
zilspeed - 6/1/08 at 08:10 PM
I also have VAG COM here.
As stated above, it positively discourages even looking at airbag modules unless you're really sure that's what you want to do.
onzarob - 6/1/08 at 08:42 PM
I've got it and used it on my airbag system, no problems and cleared the code I had.
I have a the 409.1 version and a cheap cable from ebay
carlgeldard - 7/1/08 at 07:55 AM
I removed the airbag to take the steering wheel off to get at the ignition switch. I also removed the ECU to repair a broken wire. I just need to reset the system that puts the airbag dash light on as its now on all the time. I downloaded the vag com software last night just waiting for the cable to arrive from ebay.
Carl
