Guys I have a red top facet fuel pump, running to a filter king regulator, which is then feeding a pair of webber 45 carbs, what is the ideal fuel
pressure the regualor should be set to.
About 2.5 psi as i remember.
If you have a filter King then a small cheap fuel pressure gauge can be temporeraly fitted to it while you set up.
3 psi
Mine have been set at on the rollers at 2.5 with 200 bhp and are fine
