Welding a car
nib1980 - 1/2/08 at 09:17 AM
Hi all,
I'm quite happy at welding, But I'm going round to do a mates road car tonight, are there anythings I should be aware of that are different to working on my chassis.
I know I'll be disconnecting the battery, but do you need to protect the ECU or anything?
Many thanks
speedyxjs - 1/2/08 at 09:20 AM
Iv heard of people unplugging the ECU just incase.
nitram38 - 1/2/08 at 09:25 AM
The main thing is to remove panels behind your welding area. They stuff insulation into the weirdest of places and the car owners sometimes do dodgy things.
I once set fire to an XR3i because the owner had a faulty seatbelt and had unravelled it and tied it inside the rear side panel.
I was welding seals on!
[Edited on 1/2/2008 by nitram38]
Peteff - 1/2/08 at 09:43 AM
I was welding a car once and the owners kids had stuffed opal fruit papers under the back seat, lots of them. It went up like one oh! I had to rip the seat out and throw it across the yard and hose the interior, not too much damage but lots of smoke and stink.
Mr Whippy - 1/2/08 at 09:44 AM
Find the location of fuel, brake lines etc, hidden wires under carpets. If welding near the tank drape a rubber car mat over it to stop sparks. Do make sure it’s well supported if going under, I still see people using just a jack and make sure to disconnect the alternator.
Have powder fire extinguisher next to you 1kg min.
mad4x4 - 1/2/08 at 09:45 AM
Arph Arph - (Crap seal impression)
Did the Seals object and how did you get them to sit still long enough.
"don;t you mean sills."
turbodisplay - 1/2/08 at 04:51 PM
Once welded a chassis on a car, unaware that those plastic lines were fuel lines. Reaslised what they were when I noticed they were close enough to the welding to melt.
When it had solidified i touched the line to discover it broke and squirted a good few cc of fuel. A few more seconds of weldingr and I could have been very badly burnt.
Always check what is near to the weld.
Darren
