Relays
NigeEss - 13/2/08 at 12:44 AM
Are the numbers on the terminals a universal standard ? Need one like
the number 4 at top of page here VWP.
I have one in my box-o-bits with corresponding numbers. will it be the same ?
Mr Whippy - 13/2/08 at 02:43 AM
as far as I'm aware yes it's a standard coding system, but just to be sure it's the same I'd still prise of the cover and have a shifty
u know I really feel like a beer just now but it seems a bit early in the morning, oh sod it I'll have one
[Edited on 13/2/08 by Mr Whippy]
iiyama - 13/2/08 at 07:34 AM
They are a standard numbering system. The numbers are also on the Relay.
nitram38 - 13/2/08 at 08:35 AM
The relays normally have a diagram on them so no need to try and get the cover off , Mr Whippy!
David Jenkins - 13/2/08 at 08:50 AM
You should be aware that there are 2 patterns of connector layout.
This Vehicle Wiring Products page shows it really well.
HTH
(who's just bought a relay off them!)
Doh! Just re-read the original post - with a link to the same VWP page... :blush:
[Edited on 13/2/08 by David Jenkins]
02GF74 - 13/2/08 at 10:09 AM
yes. beware of the one that has snubber diode fitted since the coil can only bewired one way on those.
britishtrident - 13/2/08 at 12:38 PM
Maplin are cheaper than the usual places for automotive relays.
Rather than using that type of relay I would use two seperate 4 blade relays.
