I run a medium sized factory and need a decent cordless phone for when I’m away from my desk and doing the factory walkabout and odd jobs.
I mentioned this to one of the plumbs that works up in the purchasing office and have been presented with a home style cordless phone, it looks lovely
but wont last 5 minuets in a factory environment and you cant exactly fit it in your back pocket. I have told him to send it back.
Does anyone know if it’s possible to get a traditional mobile phone (or a more robust cordless) to work through a landline switchboard? I have a
company mobile but, I prefer to take calls through the switchboard so that I can ignore calls if needs be.
I think BT used to do a landline and mobile with the same number but can’t find any mention of it on the website.
Hope someone has the answer
Thom
If there is, il shoot them
sorry, dont like BT
Ive got a carry phone at work and a normal phone that are on the same number . The carry phone is very robust and has a good signal. It uses a hub on the phone socket so either phone can be used. Im not too sure of the make, i will check tomorrow for you.
I don't work for BT but do specialise in all things phones. One of my customers uses exactly the solution you describe of a standard DECT phone
on their phone system we installed. Ideal for wandering round the factory and v cheap way of doing things. Just select the handset wisely, there are
thousands out there.
Another solution is the Nokia mobile handsets which support wifi. With the right phone system in place these phones will register to your landline
system via wifi when in the factory/office and become your mobile as soon as you get out of range. However, it's not a simple retrofit to an
existing system.
The solution alluded to re mobile phones that BT do is called BT Fusion but is very limited and won't integrate with your phone system.
I don't want to fall foul of any rules here so if you want to chat more please u2u me.
Does anyone work who is with BT
OT.
BT are TOTAL CRAP!
I'm supposed to have an ADSL Max broadband connection, with a download speed of 5.5Meg.
BT say they can't understand why I don't get the speed ( for three days it was below 400K!), so I did a speed test on BT's web site.
The results:
Broadband checker results (14 February 2008)
We've just tested your line and can confirm your line supports the UK's most complete broadband package, BT Total Broadband and we can
confirm that you will be able to reach a maximum download speed of 0.5 (Megabits per second)
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 1500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2112 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1363 kbps
Go figure!
This is the phone that I use:
http://www.ascom.fr/ws/ot.jpg
HTH
Ben
wilkingj works for BT in Cambridge , he may be able to help
