pinto water inlet gasket?
omega0684 - 20/4/08 at 09:49 PM
does anyone know where i can get the top water inlet gasket for my pinto without having to buy a whole gasket set?
Paul TigerB6 - 20/4/08 at 09:52 PM
Not 100% sure which one you mean - is it the one on the water pump??
this one??
Burton Power are generally good for Ford bits but i got mine from the Ford main dealer at little cost.
Burton Power
[Edited on 20/4/08 by Paul TigerB6]
omega0684 - 20/4/08 at 09:55 PM
No its the thermostat gasket. - ignore this i just found them on burton's site
[Edited on 20/4/08 by omega0684]
indykid - 20/4/08 at 09:56 PM
which water inlet gasket?
the thermostat housing, the inlet manifold gasket, or the water pump gasket?
all should be available seperately from any decent motor factors.
halfords should definitely be able to source them seperately too if you're stuck
tom
Paul TigerB6 - 20/4/08 at 10:00 PM
Gotcha. I got a couple of these from the local Ford dealer - they were so cheap the Parts guy couldnt be bothered checking the price so gave them to me for free. Might have a spare here - can have a look in the morning for you
Mr Whippy - 21/4/08 at 08:01 AM
make a new one, you can buy the paper sheets, though I just use card.
rusty nuts - 21/4/08 at 07:41 PM
Motor factor used to stock a kit with a new gasket , retaining clip and IIRC a seal.
