ultima building?
buncefm - 1/6/08 at 02:13 PM
when bilding an ultima do you have to buy all the parts from them or do they allow you to manufacture your own? its seems a bit steep for a set front wishbones £544 when they look as if they could be easily made!
scootz - 1/6/08 at 02:32 PM
You can buy pretty much any part individually from Ultima.
Up to you if you want to mix and match, but bear in mind that you might lose a bit of the Ultima value if you start buggering about with DIY wishbones.
