I have a P100 that I want to freshen up and I was wondering if people knew what level of interchangeability there was between sierras and P100's
(it is a sierra one not a tina)
The mechanicals and body are surprisingly good but the inside is junk.
Im gonna build a 302 for it while im in the states and use an F150 back axle.
[Edited on 15/6/08 by liam.mccaffrey]
the front struts are longer
the front crossmember is mounted with spacers.
the steering coupler is longer to reach the rack
the front hubs can be swapped for 4 stud car ones no problem
the engine mounts have built in spacers to match crossmember
there is also no rear wash/wipe on wipper stalk
no interchangeabilty problems
on the pluse side you get large diameter anti roll bar
on the minus side you get the smallest vented discs 240mm!??
[Edited on 15/6/08 by redscamp]
