Hi,
If I want to sell the number plate on my car (which is just a normal number, not a private plate), do I need to register it as mine, or do I
automatically own it by owning the vehicle?
I know it sounds like a silly question but I thought I heard once that you don't actually own the plate unless you buy it as a private plate??
Thanks,
Stu
It should say on your V5C logbook if its non-transferable.......
I dont know the answer tbh, just check the V5C first
If you were issued it by the DVLA and it is a non Q then you should be fine to sell it. As above anything that is non transferable will say on the
V5.
Guess you do own it -
No probs though in transfering a "normal Plate" onto another car.
Reason: Itransfered a plate from a 1974 landy on to my 1992 car and since then it has been moved to each car I have subsequently owned -"Private
Plate". Yet I didn;t pay DVLA for the plate it came iwth the old landy. So guess this may answer your question
I had a number on retention on a V750 that i 'bought' off DVLA. I paid the transfer fee of £80 when I bought it but the V750 only lasts 1
year.
I got a letter reminder stating if I did not extend the V750 (£25) I would loose the tranfer right and the ownership of the number. Not renewing the
V750 would result in the number going back to DVLA and I would loose all the money spent.
The number now sits on my MNR and was describedas 'cherished' when I registered the car.
Hope that helps
You don't own the VRM. The number is issued by the DVLA and can be withdrawn at any time. The DVLA own the number. You can buy the right to
display the number via several companies but it always involves the DVLA as they still own the number! And even after you have piad for the right to
display the number, should you be reported for incorrect use of that plate, it can be withdrawn.
In answer to your quezzy, you can transfer, or hold on retention, almost any VRM. But not a Q or one that has been issued to cover an age related
plate that has been lost.
Damn you double post.......
[Edited on 23/7/08 by owelly]
ok - thanks, very helpful.
Hopefully I can sell the plate, build a garage, fix the MG and finish the Locost!
is it something thats just come relevant?!
N421 MAX
