Knocking noise in reverse
speedyxjs - 23/7/08 at 06:47 PM
What could be the cause?
mookaloid - 23/7/08 at 06:49 PM
Without a few more specifics to go on, I would say something broken or wearing out or loose
speedyxjs - 23/7/08 at 06:53 PM
What else do you want to know?
It only does it in reverse. Cant be sure where it is coming from but think transmission tunnel
mookaloid - 23/7/08 at 06:55 PM
type of car?
speedyxjs - 23/7/08 at 06:56 PM
Sorry, should have started with that
Its on my midget so front engine, rwd
mookaloid - 23/7/08 at 07:03 PM
I would guess worn or sloppy engine/gearbox/axle mounts causing the gearbox/axle to knock on the body somewhere or maybe if it's the gearbox a missing tooth off reverse gear?
Mark
adithorp - 23/7/08 at 07:27 PM
OK, I'll bite...
Put a bike engine in it. That'll stop it knocking in reverse!
adrian
speedyxjs - 23/7/08 at 07:40 PM
Originally posted by adithorp
OK, I'll bite...
adrian
In a word...NO
Havnt you read whippy's signiature?
tegwin - 23/7/08 at 07:54 PM
Its proberably the back axle tramping as you go backwards...
Tends to happen in older cars as the springs/dampers wear out...apparently
Howlor - 23/7/08 at 08:02 PM
Knee on the centre console?!
skodaman - 23/7/08 at 09:05 PM
'Put a bike engine in it. That'll stop it knocking in reverse!'
Aw I was gonna suggest that.
worX - 24/7/08 at 05:11 AM
The time that someone uses something Mr Whippy says on this forum, for a side winning argument is the time to pack up and go home!!!
OK, I'll bite...
adrian
In a word...NO
speedyxjs - 24/7/08 at 06:34 AM
OK, I'll bite...
adrian
In a word...NO
splitrivet - 24/7/08 at 07:31 AM
Propshaft ??
