Sure we must have some Ford "buffs" on here!
Does anyone happen to know if the flexy brake hoses on the above RS2000 with ABS are the same as on non ABS cars & the same as any other MK4
Escort with discs - which would be what models?
I've been asked to make some hoses up & there is no catalog listing for the RS2000 with ABS.
ive had 3 all with abs and they are just standard flexys as far as i can remember as ive put rs2000 brakes on a standard mk 5/6 escort
The hoses are the same, all ABS does is control brake aplication/pressure, apart from that the system, (hydraulic), is the same. Cheers Ray
Thanks chaps!
Fords "usualy" keep to the same hoses, (being an accountant run company,
). Never yet seen a Ford that comes in standard and ABS form that
used differing hoses. Can always be proved wrong though<
Cheers Ray
