OT - O ring
JeffHs - 10/10/08 at 09:25 AM
The car's on the road so I'm back on other projects.
Does anyone know where I can get a square section O ring 1/8th inch section, 2.25 inches I.D.
It's for an internal seal in the fuel injection pump on the Bombardier engine for the Auster
[img] Bombardier for Auster
[/img]
Mr Whippy - 10/10/08 at 09:36 AM
for a plane engine that looks rather robust, built like a lathe really
02GF74 - 10/10/08 at 09:37 AM
Hav you tried the square o-ring shop?
seriously though, a very very long shot ... take a look at oil filters - it does sound like the sealing ring on those could be the right size ....
I should have one knocking around somewhere so can measure when I get home and if I remember.
MikeCapon - 10/10/08 at 09:40 AM
Square section O rings are pretty difficult to find. Can you not use a round standard round section? The normal round O rings are designed to go into a square housing.
ETA Like this
Image deleted by owner
[Edited on 10/10/08 by MikeCapon]
hicost blade - 10/10/08 at 09:49 AM
Try Supaseal http://supaseal.co.uk/products.htm
Dave
madteg - 10/10/08 at 09:51 AM
Hope this works, its from a pipe fitting i have used in the past.
http://www.axiumprocess.com/pdf/sms.pdf
MikeCapon - 10/10/08 at 09:51 AM
Found some for you
Square O rings
vinny1275 - 10/10/08 at 09:56 AM
It could also be worth giving the IWM at Duxford a call, see if you can get put through to the maintenance section - find out where they get their o-rings and bits from.....
Vince
r1_pete - 10/10/08 at 10:02 AM
If all else fails try brake caliper seals, I've just measured some I have, which are 1/8" square, but only 2 1/8" id.
Agriv8 - 10/10/08 at 11:09 AM
Try giving Pirtec (Hydralic hose company a call ) they may have the square section rubber that you cut to your required radius and then supperglue the ends together.
Edited to add I think its called 'O ring Cord'
If not let me know and a freind may have some on his VAN
regards
Agriv8
[Edited on 10/10/08 by Agriv8]
Alan B - 10/10/08 at 11:56 AM
Shame you are in the UK...if you don't find what you want I could help you.
http://www.mcmaster.com
Item 4061T25 $7.84 per 25
I'm sure someone there will help but if not just shout.
Alan
rusty nuts - 10/10/08 at 06:33 PM
I should see a guy tomorrow who maintains planes at Duxford . If I do I will ask him and let you know.
Vince
rusty nuts - 11/10/08 at 01:41 PM
Have had a word with the guy I know , he is looking into it and hopes to get back to me hopefully on monday.
Mix - 11/10/08 at 05:50 PM
Hi
Scary stuff !!!!!
Parts will be listed in the OEM's IPC or CMM. Sourcing unapproved parts will, if declared, void the C of A / ARC and if not possibly comprimise the safety of the aircraft, crew and public.
Not advised.
Regards Mick
rusty nuts - 11/10/08 at 06:20 PM
If my contact at Duxford IWM comes up with anything it will be C.A.A. approved .
Mix - 11/10/08 at 06:29 PM
Hi
EASA approved I hope,
Regards Mick
