donor stuff for a caterham
bigshotsquid - 12/10/08 at 03:11 AM
Rover 1.6 or 1.8 K-series engine, 5 speed XR4i gearbox or Caterham 6
speed gearbox. The differential is from a Ford Sierra XR4i unit
thats all i can use? or will there be more complications ?
liam.mccaffrey - 12/10/08 at 03:23 AM
is that what you have or is that what you plan on using?
good call on the k series engine, but that wont fit on the xr4i box. i think its a mt75 without a removable bell housing so thats out unless you use a ford engine.
the 6 speed is the one you want i thinks that deisgned for the k series
differential is fine as long as its a good ratio, i think the xr4i has the lsd didn't they?
some one will probably be along to correct everything i've said now but welcome anyway
Humbug - 12/10/08 at 08:45 AM
or 1.4 K series
mackei23b - 12/10/08 at 08:46 AM
Titan do a bell ousing to match a K series to a type 9 gearbox
indykid - 12/10/08 at 11:33 AM
paint does a smaller avatar!
if it uses a sierra diff, any 7 inch unit will fit. the xr4x4 had a LSD. not entirely sure on the xr4i.
more details on your project might help us tell you a bit more specifically what you want/need.
tom
speedyxjs - 14/10/08 at 02:55 PM
1.8 with 6 speed box imo.
More power = more
bigshotsquid - 19/10/08 at 07:24 PM
