Long story cut short. The end.,
ok, maybe not that short.
I have RR diffs in my lwt so the speedo is reading incorrectly. Managed to acquire a RR speedo but this does not have the blue high bean and orange
alternator charge lamps so got some LEDs to fit into the face.
The LEDs have 2 part bezels that I measure the hole to be 7 mm becasue I hadn't realised that the bezels are fitted first, then the LED
followed by teh clip - the correct size hole should have been 6 mm.
oh well, the clip hold them securely enough but still a bit of a bummer,
Doh !
Why not change the speedo drive in the gearbox ?
didn't think of that...
actually the difference in gearing is about 30 % - not sure that there will be a gear that would do that; if there was, then I guess there would have
been no need for Land Rover to fit at least 4 different ratioed speedos. .. will look into it though.
Surprised you haven't enquired on LR4x4, Western's bound to know.
And yes, I'm a member there too (Nige90)
