Hi All
My alarm system (building not car) is showing a set fail code, can anyone give some advice on how to re-set it.
Nick
Hard to say not knowing what system it is but have you tried putting in the code then hitting unset?
YQUSTA
The system is a Scantronic 808, if that makes any sence.
I have tried putting code in and get "Set fail Z-09" on the key pad.
I will have a search but that says to me zone 9 is faulty
If it is a wire less system change the battery in the detector.
YQUSTA
Edit:
this is the user manual
http://www.alarmsbc.com/pdf/808_user.pdf
zone 9 needs to be sorted
It could be a fly or spider accross the lens inside or out.
you can omit zone 9 from the menu which will allow you to set the alarm.
If you have a look at the detector on zone 9 be aware that removing the cover will set off the alarm because of the tamper switch this can be muted by
putting in your user code.
YQUSTA
[Edited on 26/10/08 by YQUSTA]
And the installation manual too
http://www.securitycentres.co.uk/Manuals/808.pdf
Thanks for that.
The instalation manual looks usefull, I'll give it a good read.
The system is not wireless and as far as I know there is no zone 9.
If there isnt a zone 9 thats very confusing but have a look through the manual see what you can find.
If zone 9 is a door contact it could be faulty or the door may have dropped which means it wont work.
YQUSTA
Ahhhhh just phoned and got some more info from staff.
They forgot something as they were leaving yesterday and held the door open while they went in and picked it up and the alarm went off. The key pad
then apparently said "engineer reset req." It doesn't say that now, only "set fail Z-09".
Looking through the manual I could have done that, but the default engineer code has been changed (no real surprise there).
I think I'll do a 1st stage re-set which ought to let me do an engineer re-set.
What a lot of re-sets in that post
Thanks again for your input.
no problem happy to help
YQUSTA
