I have a 1.8 silvertop Zetec in my Fury. I have tried to find the engine number to ID the engine but cant find the engine number anywhere on the
block. Does anyone know why there would not be an engine number? Is there any way I can identify the camshaft that is fitted to the engine?
Many thanks
Brian:
It should be low down on the block. Its also stapped on the head by the water pump. Hope this helps.
Ian
Checked the engine and the only number on is 928M 6015 CD, when I searched online with this number it was not recognised as a Ford engine number!!!!
Looked at the head and it has 928 6090 ED on it along with another number 7K4TEA. I have searched online with these numbers but have had no luck
identifying the block or head. Does the camshafts have an identification number on them?
Brian
click on search, where is the engine number, there you will find a pic from Richard K
[Edited on 3/8/11 by Myke 2463]
I sold a 1.8 earlier this year and I struggled to find the number. Found it eventually behind the starter motor which on the 1.8 escort engine I had was on the exhaust side I think.
Linky dinky do da
Love
Rich
xx
