Heater Hoses joining
TangoMan - 3/3/07 at 11:32 PM
I need to find a 16mm T piece for my heater/expansion tank hoses.
Car Builder Solutions only do 15mm and that is all I have found on ebay.
Any ideas as I have tried the 15mm ones and they leak.
graememk - 3/3/07 at 11:37 PM
get silocone hose, its softer and clamps up better
Dave Castle - 3/3/07 at 11:43 PM
Use a plumbers 15mm yorkshire fitting the pipes 15mm but the fitting is bigger and the solder ring ridge will provide something for the clip to to grip.
[Edited on 3/3/07 by Dave Castle]
omega 24 v6 - 3/3/07 at 11:50 PM
Get a plumbers solder ring type t piece. It fits 15mm o/d pipe and as such will be at least 16mm o/d. You may need to extend it using a bit of pipe and a straight connector to get enough length for a clip.
Like this
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100123&ts=65708&id=52984
Oops I'm a slow typist
[Edited on 3/3/07 by omega 24 v6]
TangoMan - 3/3/07 at 11:55 PM
Thanks gents.
Looks like a trip to B&Q is on for tomorrow.
Russiow - 4/3/07 at 11:33 AM
Tweekys do a 16mm Nylon T for fuel and oil that would be ok proberly.....
